Problems using FreeDV software with DAX
System
Member admin
This discussion was created from comments split from: FreeDV waveform updates.
I’ve tried using the FreeDV software directly and having trouble with the transmit side configuration. For RX config I select the DAX Audio RX1 and PC speakers no problem (defaults to 44100 sample rate). But when I try to config the TX side, I select DAX TX Audio and USB mic but the sample rate is not configurable. When I try to save the config it complains that the sample rates need to be the same, but the program doesn’t let me select the sample rate for TX.
Anyone else experiencing this issue?
- 697 The Flea Market
- 121 Aurora
- 983 Genius Products
