Mouse wheel does not tune
Lou Laderman W0FK
I cannot get my mouse wheel to tune when running SmartSDR (using 3.1.12) on my laptop. I am using a Microsoft Bluetooth Mobile Mouse 3600 with an Acer laptop, running Win 10 Pro. The mouse scroll wheel works fine when I use it in a browser. Changing any of the settings in Windows on the laptop doesn't make any difference, and I cannot find any settings in SmartSDR that might affect this. I am stumped
Suggestions appreciated.
73, Lou W0FK
73, Lou W0FK
Hi Lou, the scroll wheel operates on whatever control it is over. For example, if you hover the mouse over any of the volume sliders, it will adjust volume. Try hovering over the panadapter while scrolling the wheel. Also, make sure the step increment is reasonable so that you can see (and hear) the frequency change. I would start with 100 Hz to test this out.
Len, KD0RC
That's my issue Len. The mouse wheel does not work when hovering over either the controls or the panadapter. I can click and the receiving bar, and can hover over the slider controls to see their settings, but moving the mouse wheel, or clicking on it, does nothing.
73, Lou W0FK0 -
Does the panadapter have focus, or is another window, such as a logging program, active? Click on the panadapter to give it focus, then try the mouse wheel.
Craig, K0CF
Hi Craig. The only window open is SmartSDR, and the Microsoft mouse simply does not work. I installed a Logitech mouse with the unifying receiver (2.4GHZ wireless), and the mouse wheel works fine. I installed the Mobile Mouse on my desktop and had the same issue.
Following that, I ran some further tests, and now believe that the issue is with the mouse itself. In a browser, the when itself doesn't work. If you click the wheel, an icon comes up in the browser and you can move the mouse to scroll.
Microsoft may have an answer, or I could either **** my head against the wall. Either way the pain could be the same. ;-)
73, Lou W0FK0 -
Hmmm.. strange. Maybe try a wired USB mouse to see if that changes anything.
Len
Following that, I ran some further tests, and now believe that the issue is with the mouse itself. In a browser, the when itself doesn't work. If you click the wheel, an icon comes up in the browser and you can move the mouse to scroll. Microsoft may have an answer, or I could either **** my head against the wall
73, Lou W0FK0 -
73, Lou W0FK0 -
73, Lou W0FK0
- 688 The Flea Market
- 105 Aurora
