heil 781 mic
How do i setup up this 781 Mic ,Inrad mic 629 would this be a better mic for 6400M
JOE
  • David Sexton
    Hi Joe, I am using a Heil PR781 mic with my Flex 6400M transceiver. In SmartSDR v3.1.12 software on the computer hooked to the transceiver using Menu, Profile Manager, Mic or using the Menu on the transceiver, there are two Heil mic equalization profiles in the dropdown menu. They are default PR781 and default PR781 ESSB 3_2K. Highlight and load a mic profile and give it a spin! 73.
  • NA7AA Tom
    NA7AA Tom Member ✭✭
    Both Heil and Inrad mic’s have profiles.
    I have both mic’s the 781 and 629. The Inrad 629 is hotter than the 781. The 629 drives my amp better without the highs of a DX mic. Both are very good.
    I run a 6600M and a Kenwood 990s with both mic’s
    Tom
    NA7AA
  • JOEC
    JOEC Member
    edited September 2020
    Thank u when u do set Heil profiles does this set the transmit band width and audio 20 db boost
    Joe
  • JOEC
    JOEC Member
    I have mic at home I forget model looks like 781 ,629 ill post what that mic is when home see if any of you heard of it,
    I used 781 on yaesu 3000 ,something caught my eye with 629 mic maybe because Flex sells them
    I really like everyone's input,I will be running Ten Tec Titan 425 amp with 6400M i have see how setup radio so it keys the amplifier ok..
    Joe
  • JOEC
    JOEC Member
    I decided go with 629 mic ,what adapter and cables do i need -I have Heil hand trigger squeeze trigger to key radio from my icom ICM mic.
    INRAD M-629 microphone
    INRAD M-YM RJ 45 adapter
    INRAD M-Y 8 Pin jack adapter
    INRAD M-F cable for 3.5mm FlexRadio 6400/6600
  • JOEC
    JOEC Member
    > Tom
    > NA7AA
    How far from 629 mic do you talk to sound best,
  • NA7AA Tom
    NA7AA Tom Member ✭✭
    your trigger squeeze will work, but you will be better off getting the mic with the base. Your PTT will be on the base. Nice and clean. You could use both trigger and mic base together with a “Y” adapter. Go to Inrad web site and take a look.
    Tom
    NA7AA
  • JOEC
    JOEC Member
    > Tom
    > NA7AA
    I normally sit in easy chair about 6 feet from radio desk _bad back_,with headset and mic in hand ,desk mic stands I don't use .how far from 629 do you talk into it,,thanks JOE
  • NA7AA Tom
    NA7AA Tom Member ✭✭
    About and inch or two.
    Tom
    NA7AA
  • JOEC
    JOEC Member
    > Tom
    > NA7AA
    Thanks talked Stan @ INRAD he does not know what cables I need to to use 629 with Heil trigger PPT to complete the mic system-its getting more more more confusing
  • NA7AA Tom
    NA7AA Tom Member ✭✭
    Trigger plugs into back of your Flex Radio. Stan can sell you a cable that plugs into the 629 mic then yo the 3.5 on the Flex. You still need a mic stand.
    That why I suggested you buy the mic and stand package. It will come with one mic cable as part of the package. You specify you want the cable that plugs into the mic jack on the back of your Flex
    Tom
    NA7AA
  • JOEC
    JOEC Member
    > Tom
    > NA7AA
    Your really a great help,but i dont use mic stands ,I hold mics in my hand I dont sit at a desk to talk ,I hold mic in one hand and use the heil ptt trigger in other hand .
  • JOEC
    JOEC Member
    Well my old friend from radio sport headsets ,told me his PTT foot switch that I have has RCA plug that goes to 6400M PTT rca plug on back of radio,
  • JOEC
    JOEC Member
    NRAD series M-F cable for 3.5mm stereo mic jack FlexRadio 6400/6600 transceivers. Use this cable instead of the cable supplied with INRAD M-series microphones when the microphone is not in use with the INRAD DMS-1 PTT base.
    XLR 3 pin connector for microphone, 3.5mm stereo TRS jack for transceiver. For PTT, connect a hand or footswitch directly to the FlexRadio 6400/6600 RCA phono PTT jack on the rear of the radio.
