Arduino with 100mb LAN
Mike-VA3MW
Wow, this is so cool. I can see so many add on Flex 6000 projects with this.
https://www.hackster.io/news/teensy-4-1-is-the-first-arduino-compatible-board-with-100-mbit-ethernet-2f4ff34384b6
Mike va3mw
Mike va3mw
It's why I really like Raspberry Pi. Still small and has nice built in WiFi and ethernet.
I have had Pis running for close to 2 years without a reboot. They power from battery very well too!
Will have to check out this new device!1 -
Dang... I am building a "MiniMaestro" with an Arduino Due and ethernet shield. It is HUGE compared to the Teensy. I bought a Teensy4.0, but it did not have the ethernet support, so I was saving it for something else. As soon as I got the Due and shield, PJRC comes out with exactly what I needed...
So far I have a working VFO, volume, hi-cut/width, lo-cut/shift, mute and select slice. Took a while to get the tuning rate dialed in. I will eventually have selectable tuning steps and tuning rate (how many pulses of the encoder cause a one step change). Today I will get out the smoldering iron and wire up the rest of the encoders.
Len, KD0RC
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsthat is awesome! I had a very simple idea and I don't want to share it yet since I want to do it.
I like what you are doing and it shows what you can do with the ability to communicate directly with the radio over TCP/IP and how 'easy' it can be. 0 -
I got the Arduino libraries from IW7DMH. Check out his website. He built his libraries for V2.1 of SSDR, but it is a very easy mod to make it work on V3. He had a buffer of 350 bytes that need to go to 596. I just made it 600, and it works great.
Len
