DDoS attacks
Nick Cloyes, N4CL
Nick Cloyes, N4CL Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
I am seeing many DDoS attacks in my router log.  I started a daily review of my router logs after seeing many attempts to connect to my 6700.  I had a port forwarded to the 6700, which I removed after observing the problem.  That stopped the 6700 login attempts, but I still see approximately 35 DOS attacks per day.  I would like to know if other people experience the same thing, or am I being attacked because of a security weakness.
  • Steve WS5W
    Steve WS5W Member ✭✭
    edited April 2020
    I wonder if that is where some of my disconnects are coming from. I will remove my port forwarding and see if the intermittent disconnects stop. Steve Ws5w
    edited April 2020
    Unfortunately, that is not uncommon and is likely not related to the radio.  Bad guys do this all day long with their Botnets.
    If you search back a bit, you will find Eric's comments regarding attacks on your firewall.
    Should something attempt to knock on the port that you have opened to the radio, it is similar to someone knocking on the door of your house.  They don't have the keys to get in, but they can knock.
    Since the bad guy does not have the Keys, he will not be able to get in at all.
    Steve, such an event will not cause the radio to disconnect, so you may have to look elsewhere for the cause.
    73 all
  • Nick Cloyes, N4CL
    edited April 2020
  • Nick Cloyes, N4CL
    edited April 2020
    The attempts continued for 3 or 4 days after I removed the forwarding.
  • WK2Y
    WK2Y Member ✭✭
    edited April 2020
    "I hear you knocking, but you can't come in
    I hear you knocking, go back where you been"
    Sorry couldn't resist.
    73& stay healthy.
    Bob, WK2Y
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    edited April 2020
    Wow... I wish I had 35 attacks a day.   Try more like 18,000 here!  I'm starting to get concerned about a new kind of attack where they just attempt and fail so often my router log fills up and causes the router issues.
    With the entire world shuttered and locked in behind their keyboards and monitors there are just a bunch of people with nothing better to do I guess.
  • Nick Cloyes, N4CL
    edited April 2020
    I don't like them knocking.  I am doing abuse reporting on the ones that persist.  I contacted a major university and they stopped it. I guess I'm paranoid  :)
    It's a cold, cruel world out there.
  • Nick Cloyes, N4CL
    edited April 2020
    It started before the Covid-19 crisis.
    edited April 2020
    Best of luck with that.  My place is like Mark's as well.   Thousands
    As long as any port that you have open is protected by being a TLS type connection, you are fine.  The SmartLink connection is a TLS connection.
  • Nick Cloyes, N4CL
    edited April 2020
    Thanks everyone for your comments.  Now I know I'm not special  ;)
