Transverter Interface Question
Dwayne_AB6A
Dwayne_AB6A Member ✭✭
The back of the Flex has a Receive In and Receive/TX Transverter Ports.
The Transverter has the RX Only and RX/TX Port.
What is the reason for having the two ports on the radio and Flex - It seems the one TX/RX port works fine? Do I need to connect both??
  • Joel N9LQ
    Joel N9LQ Member ✭✭
    edited April 2020
    I have XVTR A connected to my 2m xverter, and XVTR B connected to my 70cm xverter. I use RX IN A and RX IN B for my 80m and 160m receive only antennas. 73, Joel
    edited April 2020
    There are two general ways that a transverter works.  One is a "split IF" where the TX and RX sides  come out separately.  The other is "common IF" where TX and RX share a connection.  How you hook it up depends on your transverter.  The instructions that came with the xverter should show the right way to hook it up.  It sounds like yours is common IF with an aux RX port, but the documentation will let you know for sure.
    Len, KD0RC
  • David-N5PSM
    David-N5PSM Member ✭✭
    edited April 2020
    What radio are you using Dwayne?
  • Dwayne_AB6A
    edited April 2020
    6600 - It has the A and B XVTR ports each with TX/RX and RX.
    Current XVTRs I have using also each have split ports.
    Thanks David!
  • David-N5PSM
    edited April 2020
    Take a look a this,  It is from Down East Microwave for using full duplex on the 6700.
