CW rise time
Mark_WS7M
Mark_WS7M ✭✭✭
Found a very old post about CW rise times and wonder what they are set to now.
I am getting reports of keyclicks when using my SPE amp.
  • Stan VA7NF
    Stan VA7NF ✭✭✭
    edited March 2020
    Normally, with an amp, that is not enough delay.
    Listen to your signal on a dummy load and increase delay until it stops the clicks.
  • Geoff AB6BT
    Geoff AB6BT ✭✭✭
    edited March 2020
    Delay is related to rise time how?
  • Craig_KØCF
    Craig_KØCF ✭✭✭
    edited March 2020
    If the amplifier does not switch into transmit quickly enough, it will "hot switch", resulting in clipping off the leading edge of the carefully shaped CW signal from the Flex. Result: terrible key clicks.
  • Mark_WS7M
    Mark_WS7M ✭✭✭
    edited March 2020
    So what delay are you guys running?
    There are two:
    1) TX delay at the phone plugs or acc plug.  I run that at 20
    2) The CW hang time which I have tried from 25 up to 1000.
  • Stan VA7NF
    Stan VA7NF ✭✭✭
    edited March 2020
    It is the TX delay for this test.  The ones I use are (much) older QRO brand using a vacuum relay and the delay is higher than 20.  I have no experience with a SPE.  I have a 6700 so just put the second RX on a dummy load and start adjusting the timing until quiet - probably around 25-30ms
  • N2WQ
    edited May 2020
    Set CW raise time to 6 ms. 4 ms is borderline and 2 ms is a definite nightmare for the others.
  • Mark_WS7M
    Mark_WS7M ✭✭✭
    edited March 2020
    Where are you setting CW rise time?
  • Geoff AB6BT
    Geoff AB6BT ✭✭✭
    edited March 2020
    Inquiring minds want to know... (me included)
  • Mark_WS7M
    Mark_WS7M ✭✭✭
    edited March 2020
    Guess we will never find out...
  • Geoff AB6BT
    Geoff AB6BT ✭✭✭
    edited March 2020
    I won't hold my breath!
  • N3RC
    N3RC ✭✭
    edited May 2020
    Seems like a simple question? Either  you can adjust or you cant????
    KD0RC Moderator
    edited May 2020
    Rise time is not adjustable in the Flex. Looking at the QST review, I seem to remember it was around 5 ms which is the textbook sweet spot. The shaping is very good so the barefoot Flex is not likely to generate bad clicks. I will have to look at the band using full duplex to see how wide my 6400 keying is. The higher the keying speed, the wider it will be. 73, Len, KD0RC
