Mouse
Terry L Angle
I am new to Flex with a 6400M. I have set it up with a monitor with the HDMI. I now want to set up a mouse for the monitor. Having problems finding where in the manual how to setup the USB mouse. Please help
You can not control the radio in this configuration and can not set up a mouse via the flex USB in the back of radio. The hdmi out to a monitor only provides a larger display to look at.1
You need to download SmartSDR to have mouse control and Flex control to function. Then you can play all you want on the monitor.0
My system is hooked to pc lan hdmi out to monitor mouse work fine0
The radio is not designed for mouse control, it does not have a mouse driver. the mouse is intended for the client side, not the radio side. Installing SSDR for Windows on a Pc or any like device will give full mouse support.
It is no problem Joseph. Plug a USB mouse into your computer. It will work with SSDR which is part of your radio.
-Robby
HP3SS
- 685 The Flea Market
