PGXL Amp available in the Store
Mike-VA3MW
edited February 2020 in New Ideas
All
I have a few PGXL's in the store now if you are interested.  Shipping is in about a week or so.
Info:  https://www.flexradio.com/powergenius-xl/
Store:  https://shop.flexradio.com/powergenius-xl. <--- fixed link
Key Features:
Harmonic Load in the Filter Box. High pass filters for routing all
generated harmonics to a dummy load. Improves linearity and increased
total power output.  No other Amateur amplifier has this feature.
SO2R – Single Operator, 2 Receivers (full-duplex receive, on the band
you are not transmitting on, and one transmitter that can switch between
bands in milli-seconds.) (Some antenna requirements necessary.) Hold
conversations on two bands simultaneously and boost your contest
scores.   No other Amateur amplifier has this feature.
Integrated Operation. When connected with Ethernet to a SmartSDR
radio, it appears that you are operating a 1500 Watt Transceiver. The
power output, SWR and metering are seen on the SmartSDR control panel
are that of the PGXL.
MEffA (Maximum Efficiency Amplification). Different PA bias
settings and drive levels for most linear operations, such as SSB, and
most efficient operation for signals without an amplitude component,
such as CW, RTTY or FM. The most linear mode (named AAB) has
a higher idle current and lower drive. Highest efficiency mode (named
AB) has lower idle current and higher drive levels. closer to a push-pull
Class C in the most efficient mode (named AB).  No other Amateur amplifier has this feature.
Ethernet control and monitoring. Ethernet and one (or two, in the case
of SO2R) RF cable. No bundles of control wires. Enables full long-distance remote operation together with a FlexRadio Series 6000.
Works with other HF radios as well for band tracking and SO2R operations
eHam reviews:  https://www.eham.net/reviews/view-product?id=13931
Many 73
Mike 512-535-4713 Option 1
0 votes
In Review · Last Updated
