How to interface Yaesu FAS 1-4 antenna swich with 6400 for auto swithing
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI had a quick look at the manual for the FAS, and it 'can' be done, but it will not be a plug and play solution.
You will have to break out the **** driver and interface a Bit mapped relay board that will essentially work in place of the remote switchbox. This is described in the USB document on the download area.
This is the board https://www.amazon.com/SainSmart-Eight-Channel-Relay-Automation/dp/B0093Y89DE
BIT Cables
BIT cables provide a means to map the tuned frequency of the radio to a set of individual signals/wiresat the end of the cable. These cables are designed to control external devices when the radio is tuned tospecific bands or frequency ranges, and for external keying or sequencing that is triggered when thetransmitter becomes active.
The signal that appears on each bit/pin of a BIT cable is configured by use of the controls in the USBCables menu:-
● Pin – Enables/disables each pin/bit individually
● Polarity - Controls whether the pin/bit is high or low when triggered
● Source - Determines which source is used as the frequency check for this bit/pin. The sources
are the same as for the CAT cables, listed above.
● Trigger - Determines the band/frequency range that the source must be within for this bit/pin to
be active.
● PTT - When set, the pin/bit will become active only when the radio is in transmit and the source
frequency is within the output band/frequency range. Individual pin/bit PTT and TX Delays canbe set and will be used by the radio when keyed.
Thanks for vey valuable info will take close look how to interface with a flex radio
Dan VE2ZC 73'0 -
Thanks mr. Michael was a excellent solution.0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
