Maestro and SmartSDR CW - Same Key plugged into radio?
N0EG
N0EG Member ✭✭
edited January 2020 in Maestro
I just received a new 6400 / Maestro.   I work from home and have a work computer sharing the same keyboard with my home computer that has SmartSDR.    So, to alleviate the need to go back and forth between the computers I've been using the Maestro when I'm "working".
Is there a way to use my CW Key plugged into the radio itself for the Maestro AND times when I'm using SmartSDR?  Or do I need either 2 keys or a switch?
Thanks!
Josh - N0EG
Best Answers
  • N0EG
    N0EG Member ✭✭
    edited January 2020 Answer ✓
    Yup... didn't have the audio output switched to the powered speaker... all works now.  Thanks Duane!
  • N0EG
    N0EG Member ✭✭
    edited January 2020
    "I have mine plugged into the rig and it works fine in both situations."
    I must be doing something wrong as when I have it plugged into the radio and use the maestro I have no side tone volume.
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited January 2020
    Use powered speakers plugged into the 6400 instead of the Maestro speaker.
  • Duane_AC5AA
    edited January 2020
    Happy to help when I can!
