LOG4OM V2
2»
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited February 2020
    Sergey, if interested I am running second slice. You have to toggle between them with the arrow next to the freq display so its not as elegant as I like but it certainly works.
  • Sergey KN7K
    Sergey KN7K Member ✭✭✭
    edited March 2020
    Hi Rich,
    I enabled 2nd slice on radio and toggle arrow on the log between 1 and 2 and second window stay empty. I looked around, checked Omni rig, could not find what's wrong.
    My LogHX shows 2 slices with no issues with Omnirig.
    Sergey, KN7K
  • Rich McCabe
    Mine works fine but I was being **** to start. I created two virtual ports in SmartCAT for Log4OM so I had two dedicated ports. What I failed to catch was I had both ports pointing at slice A.
    Once I got that individual port connected to the correct slice and set Omni Rig (version 1)  Rig 1 to the right port and Rig 2 to the right port it worked.
  • Sergey KN7K
    I have separate Com port defined for Slice and B, Log4om does not see slice B.
    Another log that I use is LogHX see both slices.
    I probably could figure it out if I dig more, but the fact that whole log looks very blurry on 4k Monitor turn me off from trying.
    Sergey, KN7K
  • Patrick
    Patrick Member ✭✭✭
    There is a rig switch on the header for Log4OM V1 and V2... it will switch between the ports configured in OmniRig.
  • Rich McCabe
    In my experience it will let you switch between slices. But it will not let you "see" both.
    The Log4OM digital display on right is blank.
  • Patrick
    Patrick Member ✭✭✭
    There are now competing info services between Log4OM, JTAlert and I think even
    wsjt-x.  I have them all running with Log4OM v2 as some times it is handy to have a different view that seem to appear at different times.  As I use v2 I am appreciative of the effort to update a good logging app.  Some features work more efficiently and faster and logging is quicker.  All these changes in the middle of upgrading my old computer to W10 and then building a new faster computer to better work with W10 and all the other work load that I am pushing on the computer.  The effort over the last month was strenuous but in the end is a much better experience.  Learned a lot of new things as I progressed in this effort.
  • Patrick
    Patrick Member ✭✭✭
    That I know.....it would be nice if they would add a “BOTH”  selection....that would populate slice or VFO AB with out separate radio....
