Maestro freezes on transmit
The 6400 has no ATU but it is hooked to an LDG AT1000ProII in auto-tune mode so SWR is resolved.
Hi Dennis, nice system you have there. I think it's RF bothering the 6400. Now you have to track it down to find out why..
When using the key directly in the 6400 everything works fine. So I don't think the 6400 is being bothered.
yea sounds like RF is getting into your network, If your running on a wireless connection try it on wired ethernet connection.
try moving the Router and ANY cables away from the radio and feedline as far as possible, you may want to also add some ferrite beads and read up on constant mode currents https://k0bg.com/common.html
73's
Bret
WX7Y
Dennis, I know you are new to Flex, Some of us have been doing this a long time with Flex radios. It is RF. There really is nothing else that would cause a lock up. Other than connectivity issues, a drop out.
Look to make sure you have chocks on both ends of the Lan cables. they are a great RF antenna. The end from the switch or router and the other end that connects to the radio.
Sound slike you may have RF getting into the Maestro via the CW key line. The Maestro then locks the 6400 in transmit. Try some fair-rites clamp on cores on your key line. It appears that the 6400 is not bothered by RF present on the CW key line.
Sidetone: The CW sidetone is generated in either the Maestro or the 6400. The side tone audio generated in the 6400 is not presented to the Maestro. Reason: There are delays through the Ethernet, you don't want to send CW with those delays.
Gayle K0FLY1 -
When you push the Tune button is the CW key plugged into the Maestro when the lockup occurs? Try the "TUNE" with the key disconnected.0
Does the problem still occur when transmitting directly into a dummy load?0
Hi
Bret asked the first question I always ask. Are you using WiFi or a LAN connection on the Maestro?
Everyone was right. It's common mode RF currents. Got some great tips from Flex Support. I bought the "Grounding and Bonding for the Radio Amateur" book, and I'm learning how to do proper grounding and choking the lines and ethernet cables with ferrites galore. Thanks everyone! The Maestro is usable, and I'm getting excited!
Note: Do not use Powerline ethernet. FlexRadios really hate it.
I have done a bunch of testing with PowerLine and had good success.
What I learned is that never plug them into a power bar. The MOVs tend to **** the IP communication.
You do have to try different outlets as some work better than others.
YMMV.
What version of Powerline are you using? The problem was completely eliminated once I stopped using the TRENDnet Powerline 200 AV PoE+ . Maybe the PoE aspect was the culprit and non-PoE versions are better at filtering noise? I never used a power bar, only direct outlets that were only separated by 2 walls.
I have only tested D-Link and TP-Link. I seemed to have more success with TP-Link0
Like Michael, I use the TP-Link adapters without issues. In the shack I have the Flex and pc connected to a switch. The switch is connected to the TP-Link adapter. At the other end the TP-Link adapter is connected to the router/Wifi access point. I use Wi-Fi with SDR Ios through the TP-Link adapters without issues, noise or otherwise.
Sounds like a good idea to put a switch in the mix at the terminating end. Might add some filtering (?). In either case, I'll retry, with a TP-Link that is not Power-over-Ethernet and see if it handles that ok. Will save me a lot of time wiring through the attic.
@Dennis - some users have had success with Mesh installations. I am using the Amplifi setup, including a fiber backhaul between the main house and my ham shack/workshop, with good results.
I have used the TP-Link network extenders (I actually has this running at my vacation QTH to a router in that ham shack) and with much less success the Netgear version.
I struggled with ethernet-over-powerwires gear I tried, mostly because that trial was in a 100+ year old home where the electrical feeds were overlapping and came from different sides of the 220v feeder when broken down to 110v.
You can search the community on Mesh Systems (use Google but restrict it to just this site) and I think I wrote up the Amplifi products at my blog.
Steve
K9ZW
Blog: http://k9zw.wordpress.com1 -
Just an update: I went to some older TP-Link Powerline units, and everything works great! So the problem must lie in the Power-over-Ethernet (PoE) newer versions I tried initially. TRENDnet 200AV PoE version doesn't work, older TP-Link without PoE does! Very happy I don't have to rewire thru the attic. Thanks for the responses @Michael Walker and @John KB4DU!
I think you’re mixing up names - Powerline is not PoE. See https://forums.tomshardware.com/threads/power-over-ethernet-poe-vs-power-line-networking.3202598/ for a better write up of the differences than I’d do. Glad you have a Powerline solution that works for you. 73 Steve K9ZW Blog: http://k9zw.wordpress.com0
It was Michaels suggestion that helped me avoid pulling more ethernet cables through the attic. Good that you're in business.
No I get that. My first Powerline HAS PoE (i.e. it is Powerline by TRENDnet that supplies PoE as well). The older TP-Link I have doesn't.0
Exact same thing happened to me tonight. If MultiFlex works great but SmartLink locks in Tx, could it still be RF getting into the LAN cable? Chokes abound on the LAN / DSL lines too.0
I am having perhaps a similar issue w/6600 and Maestro A using SSB Phone. V 3.7.4 (Issue observed in V 3.3.33 as well)
I have been using SmartSDR Windows and Mac over Wifi for years with no issue. At times with 600-800W.
Now working with Maestro, with as low as 10 W, after transmitting, when I un-key the PTT the Maestro LEDs flicker and turn off with these messages on the screen:
The 6600 is still alive and functioning as I can connect to it with SmartSDR while this screen is displayed in the Maestro. From the times I was able to test, the TX audio makes it out, it just gets unhappy when the PTT is released. Seems to happen more often on transmits longer than ~10 seconds but I cannot verify that 100%.
I have toroids all over the radio room and a 1:1 isolator about 7 feet before the feed line enters the building.
Maybe someone has seen similar.
Sure sounds like RF getting into the Router or Ethernet cables
Does it do it when operating into a Dummy Load?
What power level are you running when it happens? TRY LOWER POWER
Are you running Wireless or Wired on the Maestro? TRY THE OTHER
Have you tried a NEW higher quality Ethernet Cable if your running Wired? MAKE SURE Ethernet cables ARE NOT running parallel to a RF Cable
- 407 Community Topics
- 704 The Flea Market
- 204 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
