VHF Contest this weekend -- Share your Flex setup.
Mike-VA3MW
I am an HF contester.
However, the ARRL VHF Sweepstakes is this weekend, so I wanted to share what I am thinking of.
First, after reviewing all the rules, I see I can use just about any mode, (SSB, CW, Digital, FM, etc) which is cool.
I also learned from the last VHF contest, that they relay on skeds .. alot. But, if I can see them, I can work them and maybe I can see some skeds in progress.
I have a 6600 with a 2M Transverter from Q5 Signals. I also have another all band radio on 432Mhz.
Let's talk about 6M and 2M:
With the 4 slice 6600, I am setup on the Maestro with 2 slices. I'm going to use these 2 slices for 6M CW and SSB and 2M CW and SSB. The waterfall and panadapter give me an amazing view of what is going on at a glance without having to keep spinning the dial. This is a real plus.
Next, thanks to MultiFlex (part of V3) I have another 2 slices open, again 1 on 6M and another on 2M for Digital modes so I can be on FT8 and/or MSK144. And, with the panadapter/waterfall that gives to about a 4hz/pixel resolution (I think that's the number -- it is pretty small).
With 1 radio and 1 transverter and with 1 2M antenna and 1 6M antenna I have done with would take 4 radios and 4 antennas. As well, if I had amplifiers I would have had to double up on those too.
I'm will be logging with N1MM which sees this as 2 unique radios (like an SO2R setup).
Next, toss in some WSJTx with Slicemaster, I'll start to see spots on the waterfall too. Even better situational awareness.
Here is what the 2 slices on the desktop look like for the Digital work.
Then, on the Maestro, we can do this with 6M on top and 2M on the bottom.
I look forward to hearing what others might be doing?
Mike va3mw (FN03) -- for some of you, beam north!
2
Mike, can you elaborate on why you are using MF vs. running all 4 slices as a single user? Why are you splitting the band into analog and digital modes, doubling the number of slices? Understanding your thinking and design goals would be very helpful.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNo reason. I like the knobs on the Maestro for spinning. I could use a FlexControl Knob as well I guess.
I'm splitting since it allows me to dedicate a slice each to digital if that answers your question.
I'm not even sure this is going to work the way I want it to. I might have to run 2 copies of N1MM on 2 different computers or maybe 3 since I also want to have my 433 radio ready to log. As I type this, I think that is the only way this may work, even for a single op.
The good news is that thanks to the design, I can do that. What we are seeing now the radio hardware is exceeding the contest logging software.
I might have a different view after the weekend. This is why I am trying this.1 -
Good luck in the contest! Hopefully the airwaves are not frozen up there. Let us know how you end up setting things up.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI had a great time on the contest this weekend. It is always amazing just how far you can get an RF signal to travel. Friday night I did a 432Mhz FT8 contact at 591 km'.s or about 370 miles with my 433 100 watt radio and 20 elements 430 beam. Amazing.
Like I thought I had to make some changes to my configuration. N1MM, an amazing contest product, was able to handle the Maestro and 2 slices on the 6600M (I didn't use the M part since the radio was just not close enough). On the Maestro I did SSB and some CW. N1MM was running on a laptop by itself. This is setup in SO2R mode on N1MM.
Then, on the PC I had another copy of N1MM that shared the Log information with the laptop (it automatically sets this up. I had SmartSDR running with 2 slices. I configured N1MM to talk to this 1 radio (not quite the same as the Laptop setup). Here, I did all my digital operations. Using SmartSDRCAT it communicated with N1MM on one RS232 port.
That left me 1 more RS232 port on N1MM, and here is where I used my 433 dedicated radio. Like the laptop, this is an SO2R setup.
I changed bands on the digital operations via N1MM and later, I made 2 unique Global Profiles (2M Primary / 6M secondary and the opposite). With these 2 copies of WSJT and Slices running, it allowed me to watch 1 band while operating in the other.
Since this is a low rate contest, I really like how this worked.
The big winner is the Panadapters. I saw QSO's going on that I was able to tailend and work the new grid. The visuals of the bands is a game changer. There was a number of 2M QSO's that I would have missed as I listened on 144.200 only to see QSO's at 210 or 220.
73 for now, Mike va3mw
Thanks, Mike.
Did you operate "Remote" from your 6600M?
Perhaps there is a video in our future showing your contest configuration? I for one would be interested.
Alan
WA9WUD0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsNo, not this time, but I could have if I was just using the Flex radio.
I'll see what I can for the video. Those can take time to view as I have to consider a few other parts in order to lay it out.
M0 -
I'm running a 6600 on 6m and a 220MHz Q5 xverter in SO2R using N1MM. I hadn't thought of using the MultiFlex feature. That might be handy just to separate dedicated FT8 slices and software. I'm already running 2 PC's, I have the other PC for the 9700 and another rig running the 33cm xverter.
Dave
N2OA0
- 692 The Flea Market
