ATU and XVERTER
Michael Wheatley
Michael Wheatley Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
ATU is greyed out when I switch to XVTR band.  Does this mean that the ATU cannot be used with a transverter?  I can't find anything in the manuals about this.
Michael -- KM6LHD
  • Mack
    Mack Member ✭✭✭
    You should not need an ATU with a transverter. ATU only works on Ant A and Ant B. Mack W4AX Alpha Team
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    The transverter should be designed to present 50 ohms to the radio;.
    What Mack said.
    There is no tuner when using the XVTR as there should never be a requirement to use it since the Transverter you are using presents a perfectly matched load.
