bhi EQ20B-DSP Noise Filter
KF4HR
I'm curious if anyone has tried the new bhi Ltd ParaPro EQ20B-DSP Parametric EQ/DSP Filter with their Flex 6000 series transceiver? And if so, was it able to increase readability and/or reduce atmospheric noise?
Thanks for the link. Unless I'm missing something it looks like the bhi Dual In-Line Filter model works with powered speakers. It would be great to hear more feedback from those that have tried the Dual In-Line Filter with their Flex.
No, as it does not have line level audio output. Both outputs are 8 ohm outputs. I had to adapt them to drive powered speakers. They were designed to drive standard un-amplified speakers. Otherwise the bhi DSP is very good at reducing noise. Especially on SSB signals. The parametric EQ provides a wonderful improvement in ineligibility.0
Pat, I assume you're referring to the bhi EQ20B-DSP unit? (I recently noticed the bhi Dual In-Line DSP Filter does have a stereo line level output.)
The original question I thought related to the EQ20B which does not have line level output. Looked at the dual in line and you are correct, the spec states line level. Something that I wish they had done in the EQ20...0
- 690 The Flea Market
- 461 SmartSDR for Mac
- 112 Aurora
- 976 Genius Products
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
