V3.1.8.145 and TNF
N4QM
N4QM Member ✭✭
There was a carrier in the middle of the passband of my 75M schedule frequency this evening so I decided to give the TNF a try to eliminate it.  Nothing happened.  Thinking it might be a radio issue I opened up SmartSDR and tried to eliminate the carrier with the TNF there.  Nothing.  Thinking it might just be too weak of a signal to eliminate, I moved down to the CW band and found a strong station calling CQ, and set a TNF on his frequency.  Still nothing, no matter how wide or narrow the setting, regardless of how deep a notch I set, there was no notch.
Am I the only one experiencing this with the latest version of software?
73, de N4QM
  • Jim  KJ7S
    Jim KJ7S Member ✭✭
    edited January 2020
    On the bottom left of the screen you will see some items, if you will, among them will be a TNF, if that is greyed out , it is OFF, click once to turn it on. good luck.
  • N4QM
    N4QM Member ✭✭
    edited October 2019
    On the bottom left of the 6400M display there is a left arrow "DISPLAY" menu popup, nothing resembling what you described.
  • N4QM
    N4QM Member ✭✭
    edited January 2020
    But your suggestion was still helpful.  I found the setting in the frequency/band touch menu accessed by touching the slice frequency readout.  TNF was turned off.  Thank you.
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    Dennis, the TNF will only eliminate the audio from the carrier.
  • N4QM
    N4QM Member ✭✭
    edited October 2019
    That's all it needs to do
  • Jim  KJ7S
    Jim KJ7S Member ✭✭
    edited October 2019
    Very Good, you did find it hi. I have a 6300 here so the computer monitor may act just a little different from the 6400 displays, but great you did find the operative ...Enjoy!!  '73' tnt  Jim
