5000A, ANC4 and Pro1b
Robert KB6QXM
I have a 5000a that I am looking to reduce my receive noise. I have purchased a ANC4 and a DX Engineering Pro1B loop. I am looking at using this in my receive chain. Can anyone give me a design idea and design constraints for the noise antenna? Anyone done this before and how was your results? Any suggestion would be greatly appreciated.
Hi Robert, I have a 6400 and a borrowed QRM 180 (similar to the ANC-4). My noise antenna is a few clip leads lying close to my network gear and the attached noisy switching supplies. The huge noise source that I had on 10 M has gone away, so I can't assess that one until it returns. The rest of the unstable growling noises are very effectively cancelled. I also have a lot of plain old hetrodynes up and down the bands, and my setup does nothing to reduce them, so I probably need to do something different with the noise antenna. In the meantime, I am using the Flex TNF function to **** the hetrodynes. I don't want too good of a noise antenna, or I am afraid that I will attenuate desired signals with the noise. My suggestion is to find the worst offender and set up your noise antenna location and length to reduce it the most. 73, Len, KD0RC0
Hello Len. Thank you for sharing your version of your noise antenna. What I would like is to find someone that has mounted a noise antenna outside. How long was the antenna? I cannot seem to find any online references to noise antennas. I will be using a separate receive antenna (Pro1B) loop and then null the noise on the loop with a rotor, then null the remaining noise between the noise antenna and loop. Hopefully that will help to reduce noise at my QTH.
Something I might try is a 5/8 wave 2 Meter antenna on my roof. I am not using it now, so I might see what it does as a noise antenna. It will be interesting to see how it behaves on different bands. Now if I can just figure out which feedline it is coming in on...
Len, KD0RC
- 418 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
