PG XL and implementation of adaptive predistortion
Tom
PG XL's manual does not provide much information about use of adaptive predistortion .
Has some of PG users experimented with experimented with it? Do we need to wait for a subsequent version of SSDR to implement adaptive predistortion? Perhaps someone from Flex can comment about this matter?
From what I've heard AP will be a future feature.
There are and have been people using it with PG XL and an Anan.0
That's interesting Bill. Do you happen to know where the -60dbm AP connector(s) on the back of the PG-XL connect to?
I can't say, I beleive Dave, W2OX was testing the PGXL with the Anan AP.0
I believe Flex has stated that when Flex implements APD in the 6000 series, the feedback output from the PGXL will be connected to a 6000 Rx port.
Howard
There are two -60 dBm connectors on back of amp. One to sample each amp output. My Anan 7000dle ANT1 connects to PGXL input B. Sample port B on PGXL connects to the RX Bypass port on 7000dle. In the software menu for Anan you need to check RX on bypass to use the external sample in. Dave wo2x1
Does this defeat the ability to use bandpass filters or preamps in the loop circuit?0
Flex has not stated exactly how APD would be connected and they have not stated if it will actually be implemented. Your guess is as good as mine but they did say the hardware is capable.0
Is there some update about the use of adaptive predistortion when a series 6000 radio is used with PG XL.
Nothing is mentioned in PG XL manual about interfacing both radio and the amplifier. Is a new version of SSDR required in order to make some use of predistortion?
Tom
Not implenented yet but it is on the list for future features. Volker, DL4RCE0
It's great to know the hardware is capable adaptive predistortion, and yes, I know it's FRS policy not to discuss future enhancements. That being said, what many users would probably really want to know is, is anyone presently working on the implementation of this feature? And if so, how is the testing going?
The PG XL works with Anan radios for APD. No attenuator needed.
No word if/when the Flex 6000 series will support APD. I find the 6700/PG XL combo to be more than acceptable on TX IMD.
A LOT cleaner than a Yaesu FTdx-3000 and SPE 1.3 or 1.5k amp.
I personally would rather see engineering resources directed towards other features.
Dave wo2x0 -
I agree. Come to think of it, I'd like to see the implementation of any new features or fixes. Not much has been happening lately.
Me too, I would have thought something would have come out before now, and I don't know how much this pandemic has effected this. But I suspect they are working on something that is needing a lot of testing, or it is taking a lot of work and time. but hey, we have a really nice radio to use till then!!0
Any updates how PGXL and APD works together? Or is this still in the development phase? I have cable ready for connections, but haven't had a change to test it yet.
Got the info on another post (APD in Power Genius). Bret WX7Y mentioned it's not ready yet.
