dxlabs set global profile when clicking a spot
Paul Lourd
Is there a way to automatically select a global profile from DXLABs when clicking on a spot? When I change bands, I need to select a different global profile due to how my Flex is setup with the AMP. I think there is a way to issue a Flex API call somehow from commander, but a bit lost on where this would go.
In Commander, you can define up to 32 user-defined command sequences, each of which can issue one or more commands to the current primary transceiver. For a Flex Signature transceiver, those commands are Ethernet API directives, some of which are documented here.
In SpotCollector, you can specify a user-defined command sequence to be executed anytime SpotCollector directs Commander to QSY your transceiver, as described here
So if Flex provides and documents an ethernet API directive to select a global profile, you can configure DXLab to issue that directive each time you QSY by double-clicking the Spot Database Entry for an active DX station.
While I monitor this forum, requests for assistance with DXLab applications will likely yield a more rapid response when posted to the DXLab Discussion Group.
de AA6YQ0
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
