Maestro not booting up
Performed a downgrade from 3 to 249 via maestro because of the monitor issues and now the maestro wont complete booting. screen gets as far as the little circles than goes dark and just sits there like me, a box of dumb rocks! connected maestro direct to my 6600, same thing! Did a couple upgrade/downgrades between 249 & 3, with same results several times. Radio plays well with other PC's on network.
**** am I doing wrong ?????
Man I am sure that can flip an OM out on a beautiful weekend!
Do the Maestro Reset:
1. Remove the battery if you installed one
2. Hold the power button until the Maestro is completely powered down, maybe 30 seconds or so)
3. Remove the DC from the Maestro for at least 20 seconds,
4. Reconnect the DC , the Maestro should boot up on it's own.
TNX Neal 4 the quick response!
I did as u suggested couple dozen times. I get the little circles during the boot up and a few seconds later get blue screen saying "Maestro" (no LOGO) for 1 or 2 seconds than screen goes dark and and and sits there. Its less than 2 months old.0 -
you will not get any support for this types A and B, because they are using **** Dell tabpet inside for monitoring, with a special OS from flexradio. This is not easy to handle because of the different Dell versions. So better change to the new type before you buy spare-parts which you never can use. The Maestro 3 (C) is the first one which has a real own display (without this **** battery from the Dell tablet in (A) and (B)) and is coming with a Latte Pande Processor for better permanece. I hope this runs better then the first two versions :-)0
- 692 The Flea Market
- 119 Aurora
