MultiFlex DAX weirdness
Gary NC3Z
Gary NC3Z Member ✭✭✭
edited July 2019 in SmartSDR for Windows
Another oddity with MultiFlex. If I have a RX running on the 6600M front (no DAX) and then start SSDR V3 and turn DAX on for SSDR's first RX the DAX works but the slider control for output level does not change the output level.
If I then add another 2 RX's on SSDR and turn it's DAX's to 2 and 3 and adjust DAX 3's level then DAX 1 now adjusts!
If I close SSDR with those 3 active and open again I get the same issue, I have to close RX3 and then reopen before DAX 1 level will follow the slider.
I am baffled.
