Lost SDR software due to hardware failure
Pat WW9R
The hard drive on my computer failed. I was currently running v2.4.9 of the SDR software. I planned to upgrade to the latest version now that it is out. When I get my new computer, do I need to install v2.4.9 first and then install the new version 3? Or should I just buy the new version and install it?
Pat WW9R
6600
Pat WW9R
6600
Pat, if you'd like to upgrade to v3, simply download and install the latest v3 software. No need to install v2.4.9.1
That is what I thought, but I wasn't sure. Thanks for the quick reply.1
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Pat
Sorry to hear that about your computer. Abed is 100% correct (as always). You an also run 2.4.9 at some point later by installed in. There is no need to uninstall 3 to run 2 (or the other way around). You can have multiple versions on your computer.
Good luck.0
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
