Speech Processor 6400/Maestro
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Mike
In the SmartSDR Users Guide, check out Section 20 starting on page 86. It is very well laid out.
https://www.flexradio.com/downloads/smartsdr-software-user-guide-pdf
Don't forget the Maestro Users Manual as well: https://www.flexradio.com/downloads/maestro-user-guide-pdf
You really want to look at 20.3.2.
The speech processor implements the W9GR Controlled Envelope Single Sideband (CESSB) peak limiting algorithm in SSB, AM and FM modes. The controls are highlighted below in the red square. The processor may be on or off and has three different settings when enabled. In the NOR or normal setting, the processor provides minimal additional gain and simply prevents audio peaks from clipping or producing power greater than the set level. In the DX setting, more gain is provided to the audio to increase the overall sideband envelope which results in a stronger signal that may be more readily heard at a distance. The DX+ setting adds even more gain increasing your talk power or “punch” without incurring significant audio distortion. DX+ is most effective if you increase the low-cut TX filter to between 200-400 Hz to concentrate your talk power in the audio frequency range that has the greatest intelligibility.
More than just pushing a button, it is very good to understand how it works so that you are not transmitting a dirty signal.
Mike0 -
Push the Mic/Speed/Pwr button.
Thanks that's exactly what I was looking for. So simple when one knows which button to push.1
As Mike mentions above, read the User Manuals for excellent detailed information.
Mike,
Sorry I am a little late to the party! I am confused about your post of April 2019 concerning ceSSB. In that post you make reference to the Flex Radio manual section 20.3.2, which says "The speech processor implements the W9GR Controlled Envelope Single Sideband (CESSB) peak limiting algorithm in SSB, AM and FM modes." From the research that I have done on ceSSB, this only works with SSB and not AM or FM. I am I missing something?0 -
I think that is an error in the manual. By definition, CESSB is just SSB and not applicable to AM or FM.
- 116 Aurora
- 323 Shack Infrastructure
- 228 Networking
