wsjtx no receive levels
bobby
wsjtx 2 installed xmt great but cant get any receive from rig thru dax win 7 see pics
Provided clearer pics for help
Bobby, You need to assign DAX channel 1 to slice A. Also, your system audio is set to go to the reserved side of DAX audio 1. That’s likely to cause you some trouble too. —Don0
Bobby: You have shown the TX DAX selection in your photo. You need to also select the RX DAX channel. Tap on the active slice flag at the top of your screen, this will bring up a menu. In the second row down you will see WNB , DAX, and AGC. Make sure the DAX selection (range off to 4 our 8) is set to match the audio input designated in WSJT.
Hope this helps
Gayle K0FLY0 -
Gayle thats what I was missing the Dax set to slice 1 in the menu pullued up by pushing the vfo knob in. I saw there was no slice indicated but had no idea how to make that happen. Thanks again.
Also picked up a cheap ublox 8 gps from amazon for 20 bucks and using it with bittimesync i can now sync my computer time with the gps without the need for internet works super.
I just stuck it with doublesided tape to the inside of the window and it sees about 16 or more satalittes.
Thanks again and enjoy!1 -
Final pics and created mic, tx and global profiles for wsjtx.
Bobby.... I went looking at that ublox GPS & did you find one with a USB type Plug or ?? Well.. I did find one ,, the USB is attached right at PCB.. I suppose you ran an usb extension cable to it ....
Thanks...0 -
Here is the one i bought with 6ft cable and extensive software free on site with drivers.
https://www.amazon.com/Waterproof-Nav...
I used the 6 ft cable in a computer usb the double sided tape on the units back to attach it to window blinds on an inside window looking out. i did not have to extend the cord.
When you goto the amazon link near the bottom of the page press compare with other items then when the compare page comes up near the bottom there is a technical details topic with links to software and various manuals and info for it, really extensive data.0
