Flex 6700 and have a Yaesu M100 desk microphone PTT not working
Jeff ODowd
Jeff ODowd Member ✭✭
The PTT on this microphone is working fine on a Yaesu rig but not on the Flex 6700. When I use MOX to transmit the audio is good so that bit works fine. I have looked at the pin outs for microphone and Flex both seem to be the same. Help!
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited April 2020
    Do you realy need help for this big problem?
    Sorry
    edited April 2019
    Does the Flex Hand Mic work on the 6700 as expected?
  • Jeff ODowd
    edited December 2018
    The Flex hand mic works perfect
  • Jeff ODowd
    This is very frustrating. The hand mike works fine, the M100 Mike works fine on a Yaesu. The M100 PTT won’t work on the Flex 6700. I’ve checked the pin outs and they appear to be the same. Someone must have come across this before. Come on Flex you must have come across this before.
  • Mike  W1BFA in Maine
    Mike W1BFA in Maine Member ✭✭
    silly question, but I have done it...  is the lock button on the top of the barrel of the mic pushed?
    Mike W1BFA
  • Johan _ SE3X
    Johan _ SE3X Member ✭✭
    edited January 2019
    Sure you have choosen the correct mic input? I use either a Shure via balanced or headset via frontpanel jack on my 6700. Need to remember to chose the correct one depending on input. Easy to oversee ..
  • Jack6600
    Jack6600 Member ✭✭
    The PTT micro switch fails over time and needs to be replaced. I found replacement switches, of all places, on Amazion.
    Amazon.com: 10 Pieces- NC NO Microswitch mini small Micro Limit Switch Lever Camera A15 : Industrial & Scientific
  • Jack6600
    Jack6600 Member ✭✭
    Sorry! I posted this in the wrong discussion. I meant to post this in “FLEX-6000 Signature Series, FHM-3/2 Microphone PTT Failure.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Jeff... a search found this discussion
    Adapting microphones for use with Maestro B — FlexRadio Community''
    It mentions something about needing a 'power adapter' for the M100 to work with the Flex??
    Hope this helps.
