6400M Internal Tuner
john
john Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
Thinking of purchasing the 6400M with the internal tuner. Is the tuner wide range 10:1 or is it 3:1? Will be using the radio with a multiband vertical antenna. I am new to this group and my first post. 73 John W9QP
  • KB4OIF
    KB4OIF Member ✭✭
    edited August 2018
    John.  It's 3 to 1.  Tuner works well if your antenna is close to 3 to 1.  I believe it does a little better than 3 to 1.  If it's a trap vertical, it should work.  Others may not work with it.   My 6400M has the tuner but I rarely use it now as I have a amp in line.  I use a KPA 500 and the KAT 500 combo.
    KB4OIF
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    The tuner in Flex radios are not designed for wide range. Although they do not mention an actual VSWR that is the limit, I recall 3:1 being mentioned, definitely not 10:1. From the hardware manual for the 6400/6600: "VSWR Range: 8.3 - 300 Ohms (80m – 10m) 6.7 - 150 Ohms (160m and 6m) It is not recommended to attempt repeated tuning of antennas with the ATU connected to antenna systems that exceed the maximum VSWR on a frequency of interest. Some antenna systems, such as physically short multiband antennas may exhibit a very narrow range of resonance (a high Q antenna) in addition to being very reactive. The FLEX-6400/FLEX-6600 ATU is not designed to tune these types of antenna systems. An external antenna tuner that is designed to handle a wider VSWR range is recommended for these types of antennas."
  • John - K3MA
    John - K3MA Member ✭✭
    edited August 2018
    You can figure out the SWR range.  300/50 = 6:1 50/8.3 = 6:1
    So it is 6:1 range on 80m - 10m
    I will leave you to calculate it on 160m and 6m
  • john
    john Member ✭✭
    edited August 2018
    Thank you all for the information concerning the internal tuner. I will order the 6400M with internal tuner, if that doesn’t work on some bands will use my MFJ tuner. Hope to order the radio in a few weeks.
  • KL4QG
    KL4QG Member ✭✭
    How can I tell my used flex 6400M has a built in ant tuner
    I 'think' it says Tuner or ATU on the back, but if you try to Tune and it works, you have a Tuner installed.
  • Pat_W5WTH
    Pat_W5WTH Member ✭✭
    I just checked my 6400 with factory installed ATU.
    Yes, there is a small sticker next to the S/N that says "ATU".
