6600 bad signal in ssb mode
Mikhail
I have bad signal on the new flex 6600. I got it 2 weeks ago. I make audio record by second reciever - bad signal. Recod from "mic stream" is very good. What can I do to have ssb good signal? I am using headset radiosport with mic em56.
I had terrible TX audio from my FHM-1 microphone. Was so bad people could not understand what I was saying. Changed to a new mic, keeping the coiled cable, and all was OK. It was either the connector or the cheap element. So my suggestion is to try another microphone to see if this helps. For me it did!
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Mikhail
Good work so far. Very helpful.
Can you do the following tests please. We want to make sure we have this as simple as possible.- Turn all EQ off
- Transmit via the XVTR port in an antenna
- Turn COMP off
- Make sure that voice peaks are about 80% of full scale. The peak level should never turn red.
Let's see if your audio still sound poor.
Please let me know how you make out.
Mike va3mw
Lasse, this does not apply, as he is using a Radio sport headset.0
Mike is giving you good help.
If you could get on the air with some of us we could get you fixed up in no time. Then we could hear what is going on.0 -
One thing to watch out for is RF getting into the radio. Toroid cores on the ethernet cable is not a bad idea.
de Roger W6VZV0 -
Signal from xvtr more better!1
Make sure dexp is off until you get everything setup ok.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI have converted this to a helpdesk ticket.0
- 684 The Flea Market
