Share: What's Your Battery Pack?
If you are willing to share with the community, please post a reply as follows:
1. Battery pack model and capacity in mAh:
2. Link (URL) for ordering:
3. Fits inside Maestro (Yes/No):
4. Auto Starting (no button push needed to turn it on)?:
5. Run time in hours that you are getting on your Maestro:
This should result in a more usable list for people purchasing a Maestro (like me), since
the advertised capacity is often "alternative fact" in this market :-)
Thanks for sharing.
Cheers,
Neal
Mogix 10400 mAh
www.imogix.com
Perfect fit
Auto start
?? no idea on run time it is for emergency back up only0 -
Polanfo Mobile Power Model Q5 (12000mAh) is one of my batteries (no longer available?). However for 3x the price ($59) they sell their newest and best version, the M20000 Power Bank Ultra Slim External Battery for $59. Here is a link on Amazon
I also have a GETIHU Power Bank Model PB-02 (13000mAh) which is .15" too wide (3.00" is max width) but I can still hold it in place with the Velcro straps (I cannot put on the battery door) . It works fine and is less money ($19.99)
I posted pictures in a previous Post Titled Maestro Battery Options
https://community.flexradio.com/flexradio/topics/maestro-battery-options
Neal,
After reviewing the batteries available that seemed to fit inside the Maestro and the associated run time, I took a different approach. I focused on finding an external battery that could plug into the Maestro power connector. I want to use the Ethernet cable connection which is not available using an internal battery (Wi-Fi only).
1. MAXOAK 50000mAh 5/12/20v Portable External Battery Bank
2. https://www.amazon.com/s/ref=nb_sb_ss_i_1_6/136-1384624-9689657?url=search-alias%3Daps&field-key...
3.Does NOT fit inside Maestro=no
4. NOT Auto starting (has power button)
5. Run time with Maestro using 1G Ethernet connection 10+ hours
6. Size = 8.1" x 5.3" x 1.3"
7. Weight = 2.77 lbs
The battery has a 12v output and the supplied cable plugs directly into the maestro with no adapters.
Best Regards,
Brian/W8WD
I was lucky enough to find the Polanfo 2000M packs on Amazon back when we were alpha testing the Maestro. I ordered two and reported my findings to Flex and it went on the list of "recommended" packs. Unfortunately it is no longer carried on Amazon or anywhere else I can find.
Like David, I also have two of the Polanfo 2000M, but just recently purchased two of the Quslly 20000mAh batteries here: https://www.amazon.com/gp/product/B0792Y6XTP/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 They fit in the Maestro, auto start, do not know run time. I use some of these for other purposes-take them to the beach incase the phone or Bluetooth speaker batteries die. I am going to take the Maestro to the beach tomorrow for field day.
I can not take the credit for this as someone posted that battery find a few weeks ago.0
Yes, David this is a good find. I ordered a blue one, it arrives Sunday. With a 20000mAh rating it should last even longer than my other batteries.
So I know the Maestro likes 2.5A so the 2.1A from this battery pack isn't an issue?0
Guys Do a run time test when you get that battery. Many vendors lie about specs, and that battery is not twice as large as the 10,000 mah.0
I purchased 16 18650 Lithium Ion batteries and paralleled 4 sets of 4 batteries in series. Fully charged it is 3.7 volts X 4 batteries = 14.8 volts which is under the 15 volt spec. Paralleling four packs of four gives me 12 amp hours which lasts a very long time (haven't ever run it long enough to deplete it).
The whole thing fits in a small travel pouch dimensions 4.5" X 7.5" X 2.5".0 -
Mike: I can't see clearly if you are using BMS (Battery Management System) boards in there to keep your cells balanced. Very important for maintaining cell balance to avoid eventual fire.
Neal0
- 694 The Flea Market
