Auto Bandswitching Module for ICOM IC-2KL, IC-4kl and PW1 Amplifiers
2»
  • Burt Fisher
    Burt Fisher Member ✭✭
    edited August 2018
    I have a 2KL with the 10 meter option installed so whats the story now?
  • Ed Johnson
    Ed Johnson Member ✭✭
    edited August 2018
    Burt,
    What is your amateur call?  The same applies to the 2kl as the 4kl except the connector to interface with is a cinch jones type connector instead of a din connector if I remember correctly.  You need 8v, the band voltage for 10 meters and ground going to that accessory connector.
    Ed W2PH
  • Ed Johnson
    edited August 2018
    You also need 13vdc to enable the amplifier to turn on to the same accessory connector
  • Burt Fisher
    edited August 2018
    K1OIK, so I need 8v, band voltage and 13v correct?
  • Ed Johnson
    edited August 2018
    Yes, that should get you on 10 meters
