The Radio Selected Is In Use
David Salomon
David Salomon Member ✭✭
edited April 2019 in SmartSDR for Windows
Since installing V 2.2.8, every time the radio boots when SSDR is already started, the front screen will display "The Radio Selected Is In Use".  After I press the OK button, the display goes back to normal.  A very minor thing at worst, just thought you should know.
73 - David, AG4F
  • David Kowell
    David Kowell Member ✭✭
    edited January 2019
    same thing here     any fix yet?
    edited April 2019
    We need a bit more info.
    First, please test this on 2.4.9 and see if you still have the same problem.  2.2.8 is pretty old now.
    If you still see the same issue, please send a screen shot of the message.
