Allow more than one slice to send to the same DAX stream
David Salomon
David Salomon Member ✭✭
edited April 2020 in New Ideas
I run multiple, simultaneous digital decoding on my 6600M.  I set different slices to different frequencies.  I use VAC to combine the streams into one, all of which are fed to a single instance of the decoding software.  I have to do it this way because SSDR and/or DAX will not allow more than one slice to be set to the same DAX stream.
It would be nice if that limitation was removed, allowing multiple audio streams to go to the same DAX stream.  This would remove the need for VAC and the associated audio lag (albeit very, very small).
0 votes
In Review · Last Updated
    edited April 2018
    My first thought is the possible interference and resulting signal degradation that the audio from one slice might have on the others.  Like putting 4 slices on different frequencies of a pile-up and listening to all of them at the same time.
  • K5CG
    K5CG Member ✭✭
    edited October 2018
    Is running multiple instances of the decoding software not possible or just not desirable?
    Which software is that?
  • Ken Hansen
    Ken Hansen Member ✭✭
    edited June 2018
    Sounds like what you want is for flex to incorporate VAC software into their SSDR software - since VAC already exists, what would be the benefit of such an exercise? (Not trying to be snarky, but it seems a non-trivial effort that would only recreate something that already exists.)
  • David Salomon
    edited April 2020
    Tim - you'd be surprised.  Like I said, I do this with VAC and it works fine.
    Danny - running multiple instances is not desirable, but is certainly possible.
    Ken -  I think DAX already is virtual audio cable-like functionality.  I was just suggesting that it be taken one step further, simply to reduce the third party tools required to accomplish what I want.  Less interconnected stuff = less possible problems.  You comment did not come across as snarky.
    73 - David
