DAX will not connect to radio
Winn Hall
DAX will not connect with radio so programs like Winlink will not run. Flex 6300, S/n 4515 5045 6300 8647. Software V 2.0.19 Windows 10
Is your firewall on or the network card marked public? Mike0
Does DAX load, displaying its window? Are the proper slices activated in both DAX and SSDR, with your digital software pointed at the same DAX port (not reserved) on RX, and DAX TX for transmit?0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsAdding to my previous comments, I have seen Windows updates take a Network card and change its status from Private to Public. Depending on how your firewall is set up, moving it to Public will cause your network to be firewalled off for some applications. This is one of the first things I might check.
