6400/6600 Series FPGA
based on picture send on news letter ,i bet a 2$ on that ;-)
and see no reason for change0 -
Is there somewhere on this Flex Radio Site where I can view all the newsletters?0
it repost from time to time
but think that this the one you look
https://community.flexradio.com/flexradio/topics/flex-6400-m-flex-6600-m-update-dec-12-2017
Thanks!0
Wow! You must have eyesight like Superman if you can tell the FPGA used by looking at those pictures.0
no need to be able to read part number on it ;-)
package is Ruggedized Flip-Chip BGA , very easy to see since it metal top and recess on 4 corner , only chip that use that package is Virtex-6 and the new 7 family (Kintex , Zynq etc )
problem is that new "7" use the new Vivado tool , that NOT backward compatible whit ISE ,so this force to have and maintain 2 separate dev tool and code !!
on other hand flex already have working code for the Virtex-6 to reuse and also still need to update code for old radio ,put a couple of "IF DEF" into code and you have only 1 code to handle ,much less $$$$
so i ready to put a 2$ bet on this ,but as my day job i work whit ton of PCB so yup whit time i got Falcon Eye for spot part ;-)
3 -
I'd still like to know the actual FPGA part number.
It it were me, I'd run, not walk, to Vivado. ISE is primitive in comparison.0 -
the part number was alreadu given in the thread regarding the chip updates question related to the newest malware and flex suseptabolity.0
New chipset = new coding.
Start from scratch, seriously???
Current chipset working fabulously.
Sorry Jerry I don't see the urgency.0 -
Xilinx XC6VLX75T is what I found, of course the one in the 6600M might be the next higher version
Id bet $2 on that :-)
6700 = TMS320C6A8167 + XC6VLX130T
6500 = TMS320C6A8167 + XC6VLX75T0 -
What are you talking about? Who said start from scratch? I assume the FPGA code is written in Verilog or VHDL. Porting it to a new FPGA family isn't that difficult, especially if the new family is from the same vendor--I've done it several times myself.
I've ported designs originally done on Altera to Xilinx and vice versa. It's not rocket science.0 -
What's the part number of the FPGA on the 6600?0
I wonder how much DSP headroom the FPGA’s in the 6000 radio have with the current ssdr software.
Or I guess another way of asking is, Under full load with a current 6000 radio with every thing maxed out on the current software (WNB, NB, NR, 30fps, ect..) how much DSP is left in % ?
I know this might be a bit tricky to figure out because of variance in operating conditions but just wanted to get an idea how much DSP horsepower is left for some of the cool things coming in future software enhancements.
pick one of both above ;-) ,only way to be sure it got a radio and see inside
personally i not planted to unglued the heatshink or try to JTAG for have definitive answer , on my side i prefer play whit the "Zynq" running some TARP code he he ;-)0 -
usually FPGA is wired logic ,so it not care about data load ,every ting is here and fixed used or not
cannot said for DSP but it probably similar ,let trust Flex for have room it need ;-) ,specially on new model
and if it really need it ,wly not transfer bit more processing into PC side ? noting forbid that
"and if it really need it ,why not transfer bit more processing into PC side ? noting forbid that"
So distributed processing is is still possible, That is good to know.
We are committed to a thin client / thin pipe architecture. I do not foresee offloading DSP processing to an unknown variable (consumer PC running a desktop OS) which relinquishes control of the user experience.1
yup flex is the only thin client / thin pipe , really big advantage for remote operation
my SunSDR take near 10 time the band-whit for a single "slice" and 96khz wide panadapter ,really need unlimited internet for this one ;-) may hit 32G / day !!
Any idea of how much DSP headroom is used or available currently in percentage?
Is there any way to monitor DSP load?
I do not doubt that there is plenty of DSP available just trying to get a general idea.
"I do not foresee offloading DSP processing to an unknown variable (consumer PC running a desktop OS)" Yea, please don't. The reason I finally jumped on the Flex bandwagon was because you don't do this.
Yes I'm glad the 6000 radios have very powerful FPGA's but it's nice to know if a special situation came up where offloading some of the processing to a PC would be necessary the architecture allows for this. That is just another thing that makes these radios great and “Flexible”.0
John - I need to clearly set your expectation. The current SmartSDR architecture does not allow for offloading DSP processing to the PC. It is not designed to do this.
It is the responsibility of engineering to write software in such a manner that the software features provided run on the existing radio resources.0 -
OK that's fine, I would rather have all the DSP in the radio anyway.
My original questions were:
Any idea of how much DSP headroom is used or available currently in percentage with ssdr 2.0 with everything maxed out (WNB, NB, NR, 30fps, ect..) how much DSP is left in % ?
Is there any way to monitor DSP load via radio or SSDR?
That is not a question that can be easily answered as a %. We continuously optimizing the DSP and FPGA and this happens during every release. This is what we mean when we indicate there are "under the covers" changes and enhancements.1
Well anyway I can't wait to have my 6600M in the shack.0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
