Options for remote antenna switching?
Does your antenna switch track band changes on the 6600 or do you switch antennas using the micro bit software?
I use the 1216H web Page and can use local or remote with port forwarding0
I use an SSB ACS-2004 UHF remote switch. Works great but you must manually select the ports. You control the port selection through the coax and it gets DC through the coax also so you only need to run 1 line. The current price is $475.
http://www.ssbusa.com/switches.html http://www.ssb.de/download/EN-5055_ACS%202004-N.pdf
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
