HF DSTAR with SSDR Beta v1.10.8 Issue
Cal/N3CAL
Yes. I noticed this strange behavor.0
Thanks for the reply Kent! Basically HF DSTAR is a bust with the latest software! It's almost like the record function is being used. The radio stores up your TX audio, delays it for 10-15 seconds before it actually transmits it. Then it repeats the previous audio transmissions. I've also noticed the USB Cable "DSTAR" is not always displayed even though the ThumbDV is plugged into the radio???? DSTAR still works but there is no DSTAR USB device shown (sometimes) ??
Cal/N3CAL0 -
I tried DSTAR with my Flex6300, DV-dongle and a home made 70cm transverter on my local DSTAR repeater PI1HWB and had the same problem: long delayed audio transmission. Quick responses were transmitted at the start of the next PTT-action. Sounds very weird to the listeners....
Hans - PA0HWB
I have entered this problem report into our bug tracker as issue #4400 for additional investigation. Thank you for the defect report.
I am having unbelievable issues with try to get D-Star to function on my 6700. FreeDV works just fine. Support has tried to be helpful with no success. Very disappointing. This feature has been available for well over a year and should be virtually free of issues by now. My 6700 works perfectly in every respect except D-Star. I notified support today I was returning the radio for repair along with the ThumbDV so they could correct these issues. I have also used NW's ThumbTest on my computer and it passes all test. I have also tried a friends ThumbDV - Still does not work. If anyone anywhere has a suggestion please email me at K4CAE@att.net. I am planning to ship this radio on Monday over night delivery. I left a message with support today and asked when I might expect the radio to be returned. No response yet, but it has only been a few hours. (If this is a known software issue, please just tell me.) I will wait for the next update and see what happens. Thanks for listening to my frustration.1
David,
I feel your pain and share your frustrations with getting D-Star to work reliably. Over the past year I've tried using my 6500 on D-star several times but find it's way too buggy. My hopes were the latest Beta release would address and resolve some of the prior issues but sadly IMO they make it worse. 73
Cal/N3CAL
I've still got this issue with the latest 1.10.15 update, which I loaded today, it's still the same as 1.10.8 v. Anyone else tested it ? Kev G0TPZ0
Hi Kev,
I've tested the 1.10.15 Beta as well and can confirm the delayed TX Audio issue is still there.
The Flex Change Log does not show bug #4400 as being fixed.
Cal/N3CAL
To be complete: it is not only the TX audio that has a long delay time but also the RX delay time is very long. Just compare a DSTAR reception on 2m or 70cm with f.i. an IC92 and a Flex with the DSTAR waveform. You will notice the delay time immediately. The last part of the reception data is cut off and will be heard at the beginning of the next RX session. The same procedure is true for TX. The delay i measured was 5 to 10 seconds in both TX and RX mode. 73, Hans PA0HWB.
I'm using 1.10.15.33 Beta and the current DSTAR wave form. During last nights DSTAR HF NET I talked DSTAR HF Voice simplex two way on 20m with Canada, Co, NM, ID. and on 40m MO, IL. On 80m GA and TN. I am in western South Carolina.
However, the RX delay/long echo is still there. ie #4400.2011 was the year that the International DSTAR HF Testing Net started among HAMs that had the ICOM 9100 that had the ability to operate DSTAR voice on all HF bands. Over the following years, the ICOM 7100 came out with the same ability built-in. With a software update to the FLEX 6xxx series SDR radio and the ThumbDV, that ability was added to the Flex radios. Also MoenComm came out with a GMSK modem that could be added to any HF radio that had a 9600 baud packet port and addition of a DVDongle.
Many of us participated in the ARRL National Parks on the Air, NPOTA in 2016. That was a lot of fun for the activators and the chasers. This award is not as grand or as arduous to achieve in 2017.
Starting on Jan 1, 2017 you can receive a “DSTAR HF SUPERTROOPER Dirty Dozen + Award”
To receive this outstanding certificate, suitable for framing, you must, starting in 2017-
- Make two way DSTAR HF VOICE simplex contacts with 12 other DSTAR HF voice station in 12 different 48 continental US states.
- Make at least one two way DSTAR HF VOICE simplex contact with a DSTAR HF VOICE station that is not in the continental 48 states of the USA.
- Make at least one two way DSTAR HF voice simplex contact on 5 different HF bands that the net normally meets on.
- Provide written proof (QSL CARD, Eqsl CARD), along with $3.00 US (check or cash) shipping costs for the certificate to Kent Hufford, KQ4KK, 807 Callaway Drive, Graniteville, SC 29829. Your cards will be returned with your certificate vis USPS.
On many net days, when the bands are good, you almost can work the 12 states and a Canadian station on 5 different bands. When bands gets better, we should make the Pacific and Europe again.
Kent
KQ4KK
International DSTAR HF Testing Net – WINTER Schedule –
Use your ICOM 7100/9100, or modified HF radio with GMSK & DVdongle, or the FLEX 6000 series radios with software 1.5 or better and the ThumbDV.
Here is some video of DSTAR HF Voice simplex on a 7100
We routinely have two way communications coast to coast and North to South, South to Canada, Europe and Australia. We have had two way contacts to Japan. And have been heard in South Africa and Bulgaria.
We are on each band only for 5 min. or so as to spend less time, if the band is dead we move on earlier. You can go back to a good freq after the net. MONITOR REF030C to coordinate. WE may need to move early or if the freq is busy. We do not want to step on any AM or SSB activity.
We also use a web page to keep track of who and where we are at - http://hf.dstar-relay.net/
You also can check-in to this web site anytime 24/7 to find a DSTAR HF Ham to talk to.
We have a PRENET for 30 min. before the start of the scheduled time. This PRENET is for ‘FREE FORM” contacts. One should check the web site http://hf.dstar-relay.net/ sign in and find a working freq to work on. When the net starts at the scheduled time, please join the net and follow the freqs.
DSTAR HF VOICE SCHEDULE
Sat PM 7:00 E (2400Z)
Sunday AM 10:00 E (1500Z Sunday)(Spend more time on each open band, and start on 80m)Sunday PM 7:00 E (2400Z)
Check USB/LSB on freq to make sure the freq is clear.
SUNDAY AM, we start with 80m and work towards 6 meters.6 mtrs 50.210 DV for 2 mins
10 mtrs 28.570 DV for 5 mins
12 mtrs 24.938 DV for 5 mins
15 mtrs 21.380 DV for 5 mins
17 mtrs 18.148 DV for 5 mins
20 mtrs 14.335 DV for 5 mins
40 mtrs 7.285(or another open freq) DV for 5 mins75 mtrs 3.880 DV for 5 mins.
NCS will check the freq ahead of time to make sure we don’t step on anyone 3KC up and DOWN.
"Digital voice is defined in the Commission’s rules based on content as voice (i.e. phone), not data, per Section 97.3(c)(5) of the Rules." Check out the most recent comments by the ARRL: http://apps.fcc.gov/ecfs/document/view?id=7521063715
Thanks For confirming that Cal0
Will the truncation problem at the start of transmissons ever be fixed?
Hello Lee,
Since i put a reply 11 month ago in this DSTAR section nothing has changed. The data buffering causes long delays and un-understable conversations, cut in unlogical parts. I think that when you had te develop a system like DSTAR with the Flex/Dongle as it is now, you would have had a hard job to achieve the result we get from Flexradio at the moment. There is still hope for a proper solution, but like FREEDV, DSTAR is no priority @ Flexradio.
73, Hans PA0HWB
Thanks Hans,
I was afraid of that, I guess too much interest in selling new stuff unfortunately. Wasted money on the Dongle..
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
