Best way to set up a voice recorder?
Use N1MM+. You can record directly into the program. It's in their manual. Read the Flex SO2R setup guide also. Mack W4AX Alpha Tester0
As well, Audicity is a free recording editing program that works great. Just record the voice stream in the DAX panel, put th eedited files in the proper N1MM folder, and you have the hot setup.0
There is no need to use Audicity. You can record directly to N1MM on the fly (during the contest).0
True, but I like to clip the edges and make certain it sounds right. That's just me.0
I use N1MM+ for contests and utilize their voice keyer. Is there software or hardware that can be used for casual operations, such as calling a DX station in a pileup?
Howard N8HO
Hardware: I use Stream Deck.
Software: The K9DUR DVK is as good as any. One of Ray's many SSDR utilities.
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
