frequency smartcat to ultrabeam
iz7auh
Member ✭✭✭
How to send Frequency from SmartCAT to Ultrabeam controller?
You can do it by setting up a standard CAT port in SmartSDR on your computer. You can find the procedure in the SmartSDR CAT Guide here http://www.flexradio.com/downloads/smartsdr-cat-user-guide-pdf/ . Page 15. Here is an excerpt: When in Advanced Mode, when selecting a FlexVSP com port, all available or free com ports will be shown. This list is extensive since Windows can define up to 265 com ports. Figure 9 Serial Existing Port Configuration When choosing an Existing Serial Port, the CAT COM specifies an existing COM port already present on the system. This is ideal for interfacing to hardware ports that speak the CAT language natively. Or as you may have seen in Steve Hick's last FlexRadio Insider article there are plans to integrate CAT and other features directly from the radio. That may make it into the next software release. 73, Mack W4AX Alpha Tester0
Many tnx my solution are difference because all my serial port are on raspberry on ser2net and on my PC client with VSPE call fort by TCP port , I tried to connect by SmartSDR CAT to COM port called by VSPE to TCP port of Ultrabeam Controller but not change freq....0
If it's anything like the SteppIR it should be able to work with DDUtil. I have a SteppIR and I use DDUtil.0
perhaps this helps: https://community.flexradio.com/flexradio/topics/ultrabeam-antenna-and-smartsdr-setup-guide Ray (DK6WK)0
Ultrabeam control software uses OmniRig where you can setup your connection to the CAT, I used it 2 years ago until I took it down due to problems, and bad support.
I used the Kenwood-2000 in OmniRig and later used SmartSDR. I didn't use DDutil for it.0 -
Ali nice to meet you , for now I use PST ROTATOR, but I want use SmartSDR directly, but not work ...0
Frank, did you download the Ulttrabeam control software from http://www.ultrabeam.it/site/index.php?option=com_phocadownload&view=category&id=2&Itemi...
you will need to connect the RS-232 to you computer first and then configure the Ultrabeam control software.0
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
