N1MM and SmartSDR CAT
James Kennedy-WU5E
Member ✭✭✭
N1MM constantly disconnecting from SmartCat
The moment it fails, I recreated it while all windows open
If I click Cancel this what happens I see call signs in the window.
if I click reconnect, the stream from the radio show up , There NOT suppose to be there.
this has plague me the entire contest
HELP
running windows 10
it's like there is a timer on the connection to the radio
No other software has this issue.
Jim
WU5E
HELP
running windows 10
Jim
WU5E
I don't think this was among the problems i experienced during the RTTY test. However, I di leave the radio for a nap and all was woking fine. Three hours later when i returned no DAX audio was evident. I rebooted SSDR and N1MM+ and all worked without any fuss. I suspect a Windows power management issue.
Andy K3UK
Were you using the latest version of N1MM? They fixed several bugs in their com handling logic0
Based on the N1MM website yes 1.0.524
I uninstalled and reinstalled and the same thing. I should have used FLDIGI works perfect but not the best contest software. but at least it works on 30m on rtty now
Jim, I ran all weekend with a similar configuration -- CAT to N1MM Logger+ (latest version as of 9/20), MMTTY and 2Tone. I had no issues and I know several others without issues also. Looking at what you have on the screen, it looks like there is CAT data going to output window in MMTTY. Have you gone through the setup in the N1MM Logger+ docs to ensure you have the settings right? The docs can be found here. I'll look over them and see if I can find what might be wrong. http://n1mm.hamdocs.com/tiki-index.php?page=Digital+-+MMTTY+for+RTTY+Support0
I have no issues with keying RTTY ,The RTTY Engine works just find , it's N!MM software talking to my radio on COM 5 ,so I change it to COM 8 same thing. No other software has this issue.0
It sure looks like two clients are trying to use COM5. One is obviously N1MM+. I'm real surprised to see CAT commands showing up in the RTTY terminal. Are your settings set for FSK or AFSK? I guess the trick is to find out what else is competing for COM5. A setting in MMTTY or 2Tone? Another application? Should be easy enough to isolate it.0
I genuinely think this is something in your particular environment.. I still have my setup up with no drops like your experience.. it will be interesting to find out what the issue is0
- 696 The Flea Market
- 121 Aurora
