DAX TX Switch
Bob G W1GLV
Whenever I operate digitally I always forget to turn on the TX button on the DAX panel.
Use profiles to save these settings for different modes of operation. Profiles are awesome once you figure them out. https://youtu.be/xAdz1GRbg9Y
That doesn't work. Software manual does not list anything that is saved on the DAX panel.0
I agree, I just noticed that but this is what I just did. Try turning the tx stream on in the DAX control panel and then shut down DAX. When you restart DAX it should do what you want. it should be yellow until DAX is turned on in SSDR.0
In order for the radio to have a DAX input (TX), it has to have an operation DAX source (TX stream enabled). If the DAX TX stream is not enabled, then the DAX input selection in SmartSDR will also not be enabled.
Leave the TX button in the DAX control panel always turned on.0
