Flex-3000 firewire connection issue cable ??
Marc Lalonde
HI have buy a used Flex-3000 for a club remote radio project
but have strange issue whit firewire cable when plug cable
most of time radio green led go on for 1-2 second the go off
some time not lit at all and about 1 time on 10 try led stay on
but even when if it stay on powerSDR not always "see" the radio
once it see it ,work until a cycle power
firewire card was Startech PEX1394A2V whit VIA OHCI chipset
that late PC whit 4 core I5 proccessor and PCI-e and USB3
any ida ??
73 Marc L. VE2OLM
any ida ??
73 Marc L. VE2OLM
Has the firewire card ever worked 100% ? If not then try using another cable and if still a problem, then try another firewire card. Not all firewire cards will work properly. You can also try another port for the card0
got radio only few week ago and buy card bit later since card that come whit radio was PCI
so have no historical data yet , have try to change cable but no luck0 -
The recommended Firewire chipset is a Texas Instruments. Others may have issues.1
HI ok thank
have order a Siig NN-E20012-S2 FireWire 2-Port PCIe
so hope it fix the thing ...0 -
Marc
That should work, it's the same PCIE card that Flexradio is selling in the store. I went with the, PCI version, a Siig NN-400012-S8, also sold by Flexradio, I got mine off of Amazon. Both are TI chip sets. The PCI version because I had a single PCI slot left available in this PC, and wanted to fill it first before filling my PCIE slots. Mine works great.
SDRgadgets73, Jay - NO5J
- 995 Maestro
