N1MM+ - SO2R - Transmit Focus using Foot Switch?
Rich - N5ZC
Rich - N5ZC ✭✭✭
edited October 2017 in FLEX-6000 Signature Series
I'm using Field Day as a test bed to get myself familiar with N1MM+ and SO2R operations.
Currently (while in SSB) if I change the focus in N1MM from one log entry field (slice A) to another log entry field (slice B) then hit any F-key the radio transmits using the correct slice.
However, if I change log entry focus then use my foot switch and not an F-key the transmit focus stay's in the previous slice.
The same issue occurs when I'm in CW.  If I change log entry focus and use my Key the TX focus on the Maestro stay's with the previous slice.  If I use an F-Key the TX focus changes to the correct slice and transmits the message.
Is there a setting somewhere that will have the TX focus on the Maestro (or Smart SDR) following changes in the log entry focus of N1MM+?
Thanks in advance.
Rich - N5ZC
  • Rich - N5ZC
    Rich - N5ZC ✭✭✭
    edited October 2017
    Found the answer.  Instead of using the mouse to change the entry focus, use the 'Pause' key which changes both receiver and transmit focus.
  • K6OZY
    K6OZY ✭✭✭
    edited February 2017
    You can also press control+left or right arrow to switch between radios.
