Wifi selection causes Maestro to Lockup
K7NXT
Maestro seems to work fine on a hardwired Ethernet cable to my 6500. But when selecting my wireless network, it will then lock up on the next button push. Powered everything off and then tried again, same result. Any ideas? SW is 1.7.32.15 HW version is 1.7.30.78
Here is the screen message I am getting:
Can you describe the type of network you are attempting to connect to? 2.4g, 5g? Encryption type and possibly the type of access point you are using. That might help. Mike0
Mike, thanks for your assistance. I have a dual band router (Linksys WRT1900AC). Set to WPA2 and AES security.0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
I'll pass this over to Tim and the boys to sort out. Good luck. 730
Getting the same thing here. Happened for over 45 minutes. I was trying to connect to a network with no internet access. Just an in house network. Was trying to connect to the 5.0 side. When I went to the 2.4 it started working0
- 402 Community Topics
- 693 The Flea Market
