Maestro Screen Saver
ka7gzr
ka7gzr Member ✭✭
edited April 2020 in Maestro
Will the Maestro display have issues with image persistence? I have been leaving my Maestro on many hours of the day. I have experienced image persistence problems with other LCD displays without screen savers.
Comments?
  • K6OZY
    K6OZY Member ✭✭✭
    edited February 2017
    This has been filed as a User Request in the tracking system already.   I agree!
  • KC9NRN
    KC9NRN Member
    This is also known as ghosting, modern LCD's don't typically have this issue, IPS displays have never had this issue and up until now I didn't think about it. The response will be interesting.
  • K6OZY
    K6OZY Member ✭✭✭
    edited March 2018
    I would like to have it simply turn off the screen after a user defined period to reduce heat and increase backlight LED life.
  • ka7gzr
    ka7gzr Member ✭✭
    edited December 2016
    LCD do have what's called Image Persistence not to be confused with Screen Burn-In of CRTs. LCDs do recover eventually unlike CRTs but it can take some time. Both my Icom radios (ic-7300 and ic-7850) either turn the LCD screens off or go to a screen saver.
    Jim
    ka7gzr
  • K6OZY
    K6OZY Member ✭✭✭
    edited June 2016
    Agreed.  I have had a few IPS screens I own have an after-image if a strong color is held for too long.  It doesn't damage it long term, but it does tint the next color displayed.  This is most obvious on text that then goes to a solid background.
    edited March 2017
    We are not aware of any potential issues related to burn-in with the Maestro IPS display.  Regardless, I have added this as a feature request in our bug tracker.
  • Reggie-k6xr
    Reggie-k6xr Member ✭✭
    edited April 2020
    will the new 6400/6600M models have a screen saver mode; shut off screen after a certain amount of time unused?
    thanks
    Reggie k6xr
    edited September 2017
    That feature is not in the current software
  • IZ1OQT
    IZ1OQT Member ✭✭
    To date still nothing :(
    @IZ1OQT
    I doubt that we will add a screensaver as there is no need. I have a Maestro A that has been on just about every day since they came out and there is no burn that I can see.
  • IZ1OQT
    IZ1OQT Member ✭✭
    edited April 2021
    Thanks for the info
    73...
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Sort of a “nobody does that anymore” situation.
  • ka9ees
    ka9ees Member ✭✭✭
    You need them on OLED TVs!
    Ed
    KA9EES
  • IZ1OQT
    IZ1OQT Member ✭✭
    It would also have been interesting for an energy saving speech when on battery
    Screen savers also use CPU resources to monitor for user activity and the amount of CPU power on the Maestro is limited.
    The Maestro tablet is seriously stripped down to reduce as many required resources as possible.
  • IZ1OQT
    IZ1OQT Member ✭✭
    You could put a programmable button to turn the display off and on in this way there would be further energy savings without using cpu
