Meastro and Mic in at Radio
k3Tim
k3Tim ✭✭✭
edited May 2020 in Maestro
How does one use the 6K front panel mic with the Maestro.
After a long hike to a mountain peak and setting up the Maestro and 6500 I was all set for some 20 meter SSB. The kit included only the foster mic and I couldn't figure out how to activate this mic input.  I was using the Maestro speaker but thought that routing setting was only for receive sound. Should I have set the sound from the radio and then the speaker / mic would be 'hot' in the radio.
_..--
k3TiM
  • philip.theis
    philip.theis ✭✭
    edited May 2016
    While the radio is in SSB mode, push the TX MENU button (Mic/PWR knob) and select R-MIC on the left hand side. The R- selections are on the Radio
    GL, Phil
  • k3Tim
    k3Tim ✭✭✭
    edited May 2020
    Thanks Phil - much appreciated...
    Best Regards,
    k3TiM
