Yaesu Fusion
Gary F
Gary F Member ✭✭
Are there plans soon to activate the Fusion application in the NW dongle?
  • Roy Laufer
    Roy Laufer Member ✭✭
    edited May 2017
    I would rather see a DMR decodng implementation first (as well as a more "bullet proof" D*Star implementation that does not repeatedly require rebooting my 6700 and sometimes plugging and unplugging the ThumbDV stick)...
  • KF4HR
    KF4HR Member ✭✭
    edited February 2017
    I'm active on the Fusion/Wires-X Network and occasionally hear some people using a new device called a  DV4-Mini.  I haven't tried it myself but I understand it can handle DStar, Fusion (C4FM), and DMR all in one dongle.  It would be great if this device could work with the Flex.
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited March 2017
    If I'm not mistaken HF Fusion would only be 10 meters and above?
    For the past two months I've been using a DV4Mini here in my shack.  I've tried DSTAR, Fusion (C4FM), and DMR+.   It's an amazing little USB UHF transceiver.  The latest software release DV4MF2  (2.0.0.8) works great!
    Cal/N3CAL
  • Roy Laufer
    edited May 2017
    As I understand it, the DV4Mini doesn't work like the ThumbDV in our Flex Radios, but is a computer access to these digital mode's internet based Gateways. The software is supposed to only work for Hytera's flavor of DMR Gateways (that's called DMR+), which are not used that much around here (we have DMR-MARC Gateways around here), and you appear to need to have a DV capable radio for that particular mode to get onto a remote Gateway? The point of the device is not to make a radio, multi-DV protocol enabled, but act as an Internet access for nonlocal Gateways for the DV capable radios that you already own and operate.
    I may be wrong, but that was the way it seemed to be described when I last investigated it.
    edited March 2017
    It is something we would like to do, but it isn't in our near term plans.
  • Gary F
    Gary F Member ✭✭
    edited January 2016
    Thanks Tim..I will be waiting impatiently.
