PTT in CW?
Barry N1EU
Are there any tricks for PTT to function properly in CW as MOX? I've got WinKey PTT driving the PTT input and I'm finding that sometimes the Flex 6500 correctly follows PTT and doesn't unbreak in the middle of a transmitted message (from N1MM Logger+ to WinKey to 6500 key input) but at other times PTT seems to be ignored and it keys like it's QSK. If it's in the manual, I couldn't find it. (the CW PTT works fine with my other radios)
Thanks & 73,
Barry N1EU
Thanks & 73,
Barry N1EU
One trick is you have to have Breakin enabled.
Just tried on 6500 and using FrontPanel PTT, CW works in conjunction with PTT.
Tim
I already have breakin enabled. PTT is not consistently holding TX mode in cw. It works some times but not all the time for me ;-(0
It's now clear that MOX isn't enabled in CW on my 6500. If I click MOX or push PTT manually, the receiver doesn't mute. Is there any provision to enable MOX and PTT in CW?
Thanks, Barry N1EU0 -
I figured it out! You actually have to turn Breakin OFF! Works well.
Barry N1EU1 -
But the implication of that is that your paddle will no longer work. In a contest, perhaps 95% of my cw is generated by the computer/Winkey where PTT/MOX really helps save the ears but then occasionally I need to use the paddles on breakin. Evidently Flex 6K SSDR won't support this. But a work-around would be to use a footswitch when you need to use the paddle.
Barry N1EU1 -
First let me apologize for getting this wrong.
I tested further from your observations and it appears Breakin treats CW as VoX does for voice. If Breakin is disabled one can use the radio as a very expensive practice CW generator. I recall reading that observation on this site.
Using the (front panel) PTT, I can PTT on the xmit, TX Rdy turns red, mute on and send CW via a bug connected to the ACC connector -OR- the front panel key jack if Iambic is on. But to use the paddle one has to key the PTT if the Breakin is off.
With Breakin ON, the front paddle port will key the transmitter and Iambic keyer works.
The MoX toggle allows controls the PTT of the xmit but I also hear the audio from Rcv is not fully muted but Rcv signals are gone. This seems the odd part but
Are these your observations also?
k3Tim1 -
Yes, I believe that's it.
Can I convert this into a feature request, or how exactly does one formally submit a feature request?
The request is: please support PTT in CW as MOX, even when Breakin is enabled.
73, Barry N1EU2
