intermittent lack of output modulation/power
When keying my radio using the PTT via front Mic connector, occasionally (~1 for every 20 attempts) the radio goes into transmit (Red Light, RCA TX1 engages etc) however there is no modulation from the microphone and output power.
I do not observe any problem when keying via CAT.
Flex 6700 SSDR v1.5.1.70
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited October 2015
    Have you tried it with a different microphone? Maybe the audio path is keyed through the microphone switch. However, I have never seen a microphone that did that.
  • N4TTY
    N4TTY Member ✭✭
    edited October 2015
    I was getting that both from PTT and CAT. Reset the radio and now PTT seems OK but no output via CAT. Perplexing!
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    I had that happen a few times (very few) on my rear panel foot-switch during this weekend's CQWW SSB 2015 contest.  In previous software versions it seemed to happen a lot more frequently.
    I think it also happened about once or twice in 425 contacts so far when using DAX & CAT to key the N1MM+ Voice Keyer.
    It seems to be what I would call, for lack of a better engineering term, either an "interrupt problem" or a "keybounce issue."  The engineers at FRS have been working on it and recent releases have improved the situation, but it still raises its head from time to time.
    Ken - NM9P
  • Greg Zenger [N2GZ]
    edited December 2016
    Ive been experiencing this for about a year... and it certainly has gotten better in recent software releases, but its still there.  Good to hear its being worked on.
    This is a known issue, but one that has been very difficult to determine root cause because it is so intermittent.  We think we may have found a contributing issue and that fix will be in the next release of SmartSDR.  Fingers crossed.
  • Ken - NM9P
    If it helps diagnostics  .... I seldom notice this happening unless I have DAX activated.  (though it HAS happens sometimes)
    This weekend it happened several times, and seemed to happen more often the longer I operated.  I was using DAX #4 for the N1MM+ Voice Keyer.
    BUT...It happened a LOT less than in some of the previous software releases.
    so you guys are zeroing in on it....crossing fingers.
    Ken - NM9P
    Flex 6500 w/ v.1.5.1 -- i3 computer with Win 10
