Installing MARS-ALE on FLEX 6500
Kg5dwx
I am in the process of installing MARS-ALE on my Flex 6500 opened up for MARS. The only Flex radios in the config is the 3000 and 5000. Has anyone installed this and operating? If Yes, can you give me some hints from your setup?
Thanks, I did review this post and it was very helpful in my getting MS-DMT up but the issues with MARS-ALE seem different to me.0
Here is a video I made in the past of PC-ALE and the 6500https://www.youtube.com/watch?v=dECdpU2P20k
Looks like I used Kenwood settings.
Also this old message from Steve about MARS ALE and PTT
...., FYI Hi Andy,
If you do not check RTS for PTT or DTR for PTT then its CAT PTT.
If you enter a number other than 0 for the ALT PTT port then its RTS or DTR that must be checked for PTT on that port.
/s/ Steve
- 684 The Flea Market
