Profile command failure (?)
Ron Parsons
I have several Global Profiles saved on my Flex-6300. I had this problem with SSDR v1.4.16 as well as v1.5.0. I'm not sure whether this as a bug report or an enhancement request.
My main problem is with a profile named Satellite. See attached file Satellite.
The important parameters to be saved are:
1. Number, size and placement of the panadapters
2. Name of slice (A or
3. Which panadapter is TX
When I load this profile, often I will get different results. Several of these are below.
Is this a bug? If not, please consider this as an enhancement request.
Ron W5RKN
Ron W5RKN
First, global profiles do not store panadapter "geometry" information, so this is the reason for panadapter display issue. Adding the capability is in the enhancement database.
Second, it looks like there may be some conflict between band persistence and the global profile. A global profile is supposed to override persistence, but something my not be set/working correctly. Deleting the persistence data by doing a profile export without the preferences, do a factory reset on the radio and then importing your global/TX profile data should provide some insight in determining if this is the issue.0
- 394 Community Topics
- 670 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 76 Aurora
- 319 FLEX-8000 Signature Series
- 982 Maestro
- 953 Genius Products
- 350 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
